auto) safety feature
juanelo's Avatar
11-16-03, 08:00 PM   #1
juanelo
Hi, Iwould like to ask you where is it located the fuel auto shut off reset button on a 1999 chevy suburban if there is any. thanks
mike from nj's Avatar
11-16-03, 08:38 PM   #2
mike from nj
as far as i know, only fords have these.
carefully describe your problem and hopefully someone will help you fix it.
darrell McCoy's Avatar
11-17-03, 02:54 PM   #3
darrell McCoy
None as far as I know either. Safety Swx?? Only thing that comes to mind on GM is the fuel pump runs thru the oil sender unit curcuit when the engine is running. If the engine stops, no oil pressure and no current to fuel pump. This could have changed in the past few years.
