Need help with these pesky windshield stickers!!
Old 11-18-03, 12:44 PM
Spursfan
Angry Need help with these pesky windshield stickers!!
My friend just got a used car that is in very good condition. The car looks great save for these immature butterfly and sunny face stickers on the windshield and rear shield(young female adult driver). There are also a couple stickers on the bumper. We are trying to get them off without scratching the glass or the beautiful finish. There's also the original dealership credentials emblazoned at the back(you know how they do it!!). I want someone to suggest to me how I can get this cacophony of silly stickers off the car easily. Someone help!!!!
Old 11-18-03, 12:51 PM
try heating the bumper stickers with a blow dryer. they should peal right off. it may work on the window stickers as well depending on the type. if not, scrape them off with a razor blade. thats what the inspection stations do.
Old 11-18-03, 01:34 PM
darrell McCoy
if you should have a rear window defroster or radio ant. Dont damage the wires.
Old 11-18-03, 01:46 PM
Lugnut's Avatar
ca·coph·o·ny ( P ) Pronunciation Key (k-kf-n)
n. pl. ca·coph·o·nies
Jarring, discordant sound; dissonance: heard a cacophony of horns during the traffic jam.
The use of harsh or discordant sounds in literary composition, as for poetic effect.
Now I understand what you mean. I think the auto supply stores carry an aerosol product called bumper sticker remover.
Old 11-18-03, 02:27 PM
WD 40 helps remove them also.Will soften the adhesive.
Old 11-18-03, 04:48 PM
Spursfan
Thumbs up Thanks people!
Hey Davo
What exactly is WD 40? I am not sure what that is so please explain or clarify?
Old 11-19-03, 04:32 AM
thiggy's Avatar
Spursfan - WD 40 is said to mean Water Displacement, 40th attempt.
Known as "the can with a thousand uses," WD-40 protects metal from rust and corrosion, penetrates stuck parts, displaces moisture, and lubricates just about anything. WD-40 is also great when it comes to cleaning grease, grime, and other marks from most surfaces.
CLEANS: WD-40 gets under dirt, grime and grease to clean. It also dissolves adhesives, allowing easy removal of labels, tape, stickers, and excess bonding material.
DISPLACES MOISTURE: Because WD-40 displaces moisture, it quickly dries out electrical systems to eliminate moisture-induced short circuits.
PENETRATES: WD-40 loosens rust-to-metal bonds and frees stuck, frozen or rusted metal parts.
LUBRICATES: WD-40's lubricating ingredients are widely dispersed and hold firmly to all moving parts.
PROTECTS: WD-40 protects metal surfaces with corrosion-resistant ingredients to shield against moisture and other corrosive elements.
Old 11-19-03, 04:33 AM
Lugnut's Avatar
