Blinker problem
Old 11-18-03, 05:44 PM
wingplow
Blinker problem
I have a 1994 Olds. Cutlass Supreme.
When I use the left blinker the high side of the bulb will come on but not blink. The right side works fine as does the 4 ways and the brake lights. Put in news bulbs and new flasher. That did not work. Could it be in the directional switch? Or could it be a bad ground.
Thanks
Old 11-18-03, 05:57 PM
First check the blinker fluid level. Then make sure all the bulbs on the turn signal are good.
