Brake Booster replacment 1995 Surburban
Old 11-19-03, 05:28 PM
Medic480
Can anyone tell me how to remove the clipthat holds the plunger rod to the bake pedal???
Old 11-19-03, 06:18 PM
billys68ss's Avatar
Should just be a little clip that sorta looks like a cotter pin, but is springy. Use caution as I think this also has the brake light switch attached there. Just remove the clip and slide the push rod off of the pin.
Hope this is helpful to ya,
Billy
Old 11-19-03, 09:53 PM
doclove
hi you will need a small screwdriver.On the end of the pin that the booster rod slides over on the brake lever is the retainer,put your screwdriner under that little tang and slide the washer assembly off.If you go to the dealer and get a new on you can see how it works.This bends out of shape very easily and if that happens it can come off later by its self.Play it safe and get a new one.It could be very costly.Rick
Old 11-19-03, 10:20 PM
mike from nj
i very much second that!!
get a new clip!
