door handle replacement
Old 11-25-03, 06:01 PM
ginger
I have a 1987 Honda Accord (4door). The handle on the exterior of the drivers side has broken off and is unusable. I have been advised that this is an easy replacement. I need a detailed step by step guide on how to do this. Can you help me!
Old 11-26-03, 10:11 AM
darrell McCoy
Cant give you the exact info on this particular veh, but as with most veh, window should be up, remove the door panel. With a lite look inside where the handle is. There will be 2 maybe 3 screws or nuts holding it on from the inside. Pay careful attention as to how the linkages are attached. This is not difficult task, just time consuming.
