oil in the radiator
oil in the radiator
i have a 1993 grand prix with a 3100 motor.two weeks ago the oil and antifreez was fine now there is oil in the radiator.could there be a bad intake gasket or head gasket? theres no antifreez in the oil. temperature is good. engine runs good
Check the tranmission fluid level. I have seen where the transmisison cooler may develop a crack and bleed some fluid into the cooling system. Trans pressure operates at a greater level than the cooling system so there's probably not a risk of getting coolant in the transmission. Keep an eye on the fluid level. If it was engine oil, you would probably be having a driveability problem by now.
How much oil is in the radiator? Typically if there is a problem, the oil shows up in the overflow jug. If the transcooler had a leak, it would show up as strawberry milkshake, snotty stuff in the coolant, very unattractive stuff. Either case would be a rare occurance for this model.
