Coolant Fan Relay
Old 11-28-03, 07:53 PM
Coolant Fan Relay
Does anyone know where the coolant fan relay (low) is on a 93 Escort Wagon w/1.9?
It is supposed to be next to the high temp relay and I can't find that either.
The printout from the dealer is so bad neither I nor the parts guy could tell if it was in the engine bay on the firewall or under the dash
He called over a mechanic who owns one of these and he couldn't tell either, and couldn't remember where it was
My Haynes manual has helped me identify almost all of the relays I have found, and the unidentified ones do not match up to the new relay (won't fit)
Anybody out there replaced one of these before?
Thank you
Old 11-28-03, 08:01 PM
billys68ss's Avatar
Per Alldata..... The cooling fan relay is located on the front of the left hand fender apron, to the left of the air cleaner asembly.
Hope this helps ya,
Billy
Old 11-28-03, 08:10 PM
Thank you, I will check there tommorow AM
The fender apron position was not mentioned by any of the above mentioned sources, and I believe there is a plastic cover there, I'll check under it
Also, thanks for the quick reply!
I'll post what I find tommorrow
Thanks again!
Old 11-28-03, 08:12 PM
msargent's Avatar
Memory not being what it used to be, best as i remember, Ford used the ECC module set-up on most of those cars..It's a "black box" that electrically contains the fan relays, fuel pump relay, Ac compressor relay, ect... When 1 circuit goes bad, you replace the whole thing...
Old 11-28-03, 08:20 PM
That sounds like $$$!
I have found the fuel pump and AC relays in separate areas so let's hope it's not a black box deal
(although replacing them all at once does eliminate the hunt for one at a time every few months as these cars get older!)
Old 11-29-03, 05:59 AM
Desi501's Avatar
This is true. I also have seen incorrect identification on schematics for locating these relays. Sometimes that box is behind the glove box or near the left front headlight..about 5"square and 1.5in thick with a flat screwed on connector.
Old 12-01-03, 02:26 PM
Well there it is, front of the fender apron, more like behind the air cleaner assembly, in a black box with other relays and some fuses. The two coolant fan relays are clearly marked, not which is high/low, but one relay is larger so I can guess.
So not only is this printout from the Ford dealer way off,(no wonder the mechanic couldn't remember if it was on the firewall or under the dash-it was neither!), but the relay they gave me won't fit.
I checked w/the Motorsport website and the part# listed is the one they gave me.
I guess it's back to the dealer
This time I can park it, pull the relay, and bring it up to the counter.
Thank you all for your help and advice!
