ATF Types
racefan's Avatar
11-29-03, 04:33 PM   #1
ATF Types
I have a 2001 Dodge Durango. I need to drain & refill the transfer case. It calls for ATF #4. All I can find is ATF #3. Does anyone known the diff. between #3 & #4?
YamahaWolverine's Avatar
11-29-03, 05:49 PM   #2
You need Mopar ATF +4, Type 9602, Automatic Transmission Fluid. Part # 05013457AA Do not use ATF +3. You can use ATF +4 in applications that call for +3 but not the other way around. It sucks that it is a dealer item but I'm not sure who sells an equivalent right now. I see other companies make it but who knows who actually caries it.
billys68ss's Avatar
WV
11-29-03, 07:17 PM   #3
The dealer is the ONLY place to get the ATF+4. The part number Yamaha listed is for the quart size bottle. There is also a gallon size bottle available. Part number is 05013458AA. ATF+4 is also the factory authorized replacement fluid for power steering systems on Chrysler vehicles.
Well I just found an online source for purchasing the ATF+4 fluid, and supposedly at a cheaper price than the dealer ($5.38 per quart). The site is www.moparts.com. They dont list the gallon bottle.
Hope this is helpful to ya,
Billy
According to some tests I recently read these are just some of the advantages of using ATF+4 over any other fluid in a Chrysler transmission.
Better anti-wear properties
Improved rust/corrosion prevention
Controls oxidation -Eliminates deposits
Controls friction
Anti-foaming
Superior low temperature operation
You can read about it here:
http://www.allpar.com/fix/trans.html
mike from nj's Avatar
11-29-03, 11:45 PM   #4
mike from nj
by time you pay for shipping, it will be about the same price. i know the place with the big red 'DODGE' sign sells it.
you should only need a quart and a half, that leaves you with a half quart to top off your trans and p/s fluid.
don't forget the front and rear axles too, the rear especially.
+3 is conventional
+4 is synthetic and has a unique smell
Jason R's Avatar
12-03-03, 12:32 PM   #5
+3 has a very unique smell also. You can really tell if the right fluid is in there while draining the fluid.
I've never smelled +4.
