Oxygen and MAP sensor
paramedic205's Avatar
12-02-03, 04:57 PM   #1
paramedic205
I recently bought a 89 astro van that had a 94 new motor in it. The Oxygen sensor and MAP sensors were not hooked up because the wires are to short. Can I splice those? Thank You
billys68ss's Avatar
WV
12-02-03, 05:24 PM   #2
You may be able to re-route the wires to accomidate the new locations. If not then you can splice then, just be sure to use the same type and size wire. Solder the splices rather than butt joints. You will acheive better conductivity. Use Shrink Tube to cover the spliced joints to keep them dry and insulated.
Hope this is helpful to ya,
Billy
Desi501's Avatar
12-03-03, 01:59 PM   #3
Make sure everything matches up perfectly as far as wire colors and quantity of wires before doing any splicing. You definately don't want to start crossing wires there.
