Jeep Cherokee Headlight replacement
Hello.
I'm about to buy a replacement headlamp for my 1999 Jeep Cherokee. Not much guidance in the owner's manual, other than "remove these screws, pull out the lamp, and disconnect the wire connector". Manual also mentions to replace with type "H 6054" bulbs.
1) Anyone know of any hang-ups I might run into in trying to access and/or change the bulb?
2) Any recommendations on bulb brand/options within the H 6054 type? Online, I've found:
Sylvania H6054ST - "Silverstar" Halogens @ $19.98 each
Sylvania H6054LL - Rectangular "Long Life" Halogens @ $14.00 ea
Sylvania H6054 - Rectangular Halogens @ $9.00 each
Thanks!
Thanks!
It's the Cherokee Sport.
I replaced both headlights, even though only one of them was not working. Figured it would be better to keep both the same, like you said.
Anyway, it was pretty easy. I only ran into a couple of problems:
1) The screws were quite "weathered", and loosening/removal of the screws was difficult.
2) There is a little plastic "retainer" that slips over the connection where the new sealed beam plugs in. I'm new to this, but to me it looked like it was meant to keep the headlight connection from coming unplugged. For some reason, I could not get the retainers to snap back into place. I hope the connection doesn't come loose.
