car doors freezing shut
red210c's Avatar
12-12-03, 09:40 PM   #1
red210c
Hi;
I have a 94 Cavalier that the doors keep freezing shut on when the temp drops below freezing and I was hoping sombody could recommend a method or product that might help me eliminate this problem?
Thanks;
Red
red210c's Avatar
12-12-03, 10:29 PM   #2
red210c
Hi;
Thanks;
Red
toyotaman11769's Avatar
12-12-03, 11:14 PM   #3
You could try spraying all the rubber weathersrtips with silicone spray.
Nothing much is going to help if there is a sudden change in weather. If it's wet out and all of a sudden the temp drops this is going to happen
YamahaWolverine's Avatar
12-13-03, 05:30 AM   #4
a bucket of hot water should do the trick
car nut's Avatar
12-13-03, 03:19 PM   #5
Hot water will get it open but be careful. Only use it in as a last resort. Hot water can crack windows. Then it will re-freeze & you will be right back where you started.
If you use hot water you need to then get the car inside to thaw out. Dry the door gaskets and a good dose of spray silicone on the gaskets will do wonders. This is a good preventative measure even if you aren't having a problem. I have seen door gaskets ripped off the door from opening a frozen door.
Also give the locks a shot with the little tube inserted into the key hole to prevent the locks from freezing.
billys68ss's Avatar
WV
12-13-03, 04:13 PM   #6
I have heard of people putting petroleum based or silicone lubricants on the rubber wind seals around the doors to prevent this from happening.
Hope this helps,
Billy
crt8's Avatar
12-13-03, 04:31 PM   #7
crt8
Hi red210c,your local G.M. can supply you with silicone emulsion which helps to preserve your weather stripping aswell as stopping it from frezzing to the doors.
Desi501's Avatar
12-13-03, 05:40 PM   #8
The water is what freezes. If you get it dried out thoroughly, it shouldn't freeze any more. The silicone lubrication on all the rubber is a good idea too.
red210c's Avatar
12-14-03, 02:55 AM   #9
red210c
Thank you all so much for your responses. All of the advice is very much appreciated. I'll let you all know how it comes out after the current cold snap in this area has passed.
Thanks again,
Red
Hirsch's Avatar
12-14-03, 06:59 PM   #10
I had the same problem years ago with an 88 Isuzu pickup. I used a hair dryer along the edges of the door for a couple minutes and the door thawed. Another trick that may work is sticking the key in the door if it is all metal and lighting the key head with a cigarette lighter. GOOD LUCK!!!
