fuel leak on top of tank
Old 12-13-03, 03:25 PM
merlin1965
Thumbs down fuel leak on top of tank
I have a 1990 Ford Ranger 4x4 2.9L engine.
I noticed that I have a fuel leak at the top of my fuel tank. It only leaks when the truck is running. I know that it could be a line leak or the sending unit ontop of the tank. My biggest problem is I have a 1/2 tank of gas and cannot get a hose down the filler hose to drain it.
Does anyone have a suggestion on how to get it out.
Someone told me to cut a hole into the bed of the truck to access the top of the tank, like thats going to happen.
Any help would be greatly appreciated.
Old 12-13-03, 03:39 PM
BBman
It depends what part of the country you live in. I live in northern IL and removing fuel tanks from a 14 year old truck can be difficut, best left to a pro because rust can give you problems. if you attemt it yourself we lower the tank down with gas still in it. not a very big tank so 1/2 tank is not heavy
Old 12-13-03, 04:09 PM
It might be easier to remove the bed, usually between 6-10 bolts and the tail lite harness. You would be surprised how easy it comes off.
