2001 Trooper 4wd Transmission
Old 12-14-03, 10:34 AM
Accidently drained transmission fluid. The reservoir is filled however cannot get transmission fluid from reservoir into the transmission. Any help?
Old 12-14-03, 02:24 PM
billys68ss's Avatar
Reservoir??
What do you mean by reservoir? Where did you "accidentally" drain the fluid from? The only way to drain the fluid is to take out the plug or remove the pan. Did you do one of these? If so, you have to refill using a special procedure. There is an overfill screw on the transmission and this is how you have to refill it.
Hope this is helpful to ya,
Billy
Old 12-15-03, 01:26 PM
Billy
The transmission was drained by removing the plug, when what he wanted to do was drain the oil..... I guess mistakes happen. He did find out how to replace the fluid but thanks for the response.
