1990 ford taurus not charging
Old 12-14-03, 07:47 PM
i have a 1990 ford taurus station wagon, i have replaced alternater with a new one that i had tested and is working, it has a voltage regulator thats new, battery is ok. fuses ok, car starts but battery light on instrument panel stays on constantly. i was wondering if you knew about a common charging problem with this vehical. starts fine but needs jump after driving.
Old 12-14-03, 08:31 PM
boflaade
Assuming the battery is installed the correct way, ( not the first time a battery has been installed with + to-) check the wires from the alternator. Physicaly trace them to determine if one isn't broken or grounded by a bad covering. If the battery has corrosion or the terminals are loose then that would be the start of the problem.
Old 12-15-03, 04:21 AM
billys68ss's Avatar
You say the alternator is working.... What is the voltage readings? If it is just putting out 12 volts then you still have a charging problem. Possibly a cable or fusible link problem. Does not necessarily have to be the alternator. How old is the battery? It could have a dead cell and wont HOLD a charge.
Some things to think about and check.
Hope this is helpful to ya,
Billy
Old 12-15-03, 10:13 AM
alternater is new , i had it tested on the car & bench tested. bench test is ok, when they test on car it says charging low. checked wires to altenator & fuseable links with an ohmeter everything checks out ok, battery cables test ok,battery holds charge with battery charger and starts repeatly in driveway, but when i drive car it wont start after i shut it off. battery light stays consisantly lit. battery terminals are also clean.
Old 12-30-03, 06:24 PM
problem solved ,it was a wire going to the voltage regulatar had a short in it. battery light is out now. thanks to all for your help
