back-up lights 98 ply.breeze
Old 12-16-03, 09:22 AM
mcook2503
does anyone know where the back-up light sending unit is on a 98 ply. breeze 4cyl. 5-speed
Old 12-16-03, 09:41 AM
carguyinva's Avatar
according to...
...Mitchell On Demand....it's mounted on the front of the transaxle...probably this means that it sticks out towards the radiator...look for a two wire connector with the following wire colors...white/yellow tracer AND violet/black tracer. a tracer is a stripe on the wire and you may need a good light to see the colors well...
Old 12-16-03, 06:56 PM
mike from nj
you might need to remove some air filter housing stuff to see the switch.
once you find it, put a paper clip across the two wires with the key on, if the reverse lights come on, you need a switch. if not, different problems.
