four wheel drive
Old 12-18-03, 04:12 PM
carpenter
four wheel drive
front wheel drive won't lock in Axle does spin.'83 F250
Old 12-18-03, 07:20 PM
mcourson
sounds like the locking hub needs replacing..When these things sit or are not used alot when you try to lock the hubs the insides dont work assuming these are manual locking hubs.
Old 12-19-03, 04:27 AM
slider
Have you checked out the forums on www.fordtrucks.com ? I've seen a fair amount of discussion about 4wd problems in some of them.
My truck is an '01 F350 and I've noticed that whatever the reason, if I let it get too crusted with dirt under there I have the same problem. Maybe coincidence but if I have trouble now, I wash the undercarriage.
Old 12-20-03, 06:48 AM
carpenter
tHANKS FOR THE TIP , WILL INVESTIGATE FURTHER
