94 ply acclaim eng noise when at stop
Old 12-19-03, 05:28 PM
katiefran's Avatar
Question 94 ply acclaim eng noise when at stop
For a long time now, when I stop for a red light or at a drive thru my engine makes a loud noise. People stop and do a double take to see where the loud noise is coming from. It last about 10 0r 20 seconds and then it sounds normal again. It mostly happens when the car has not been runnubg long, although occasionally it will do even it if I've been driving all day. Any thought on what is causing this. Thanks for any help or advice.
Old 12-19-03, 05:53 PM
Could you describe the noise?Squealing,banging,thumping or screeching?The original of this post was edited for content by Davo.
Old 12-20-03, 07:28 AM
katiefran's Avatar
It's not a thumping or banging. Closer to a squealing noise but not a squeal. Maybe a little similar to a revving noise but not quite that either. Sorry I can't do better tahn that. I think the people outside the car can hear it better and louder than I can if that helps any ANd it seems to be coming from under the hood.
Old 12-20-03, 02:49 PM
billys68ss's Avatar
Probably a belt or tensioner. May even be a water pump. First thing to do id open the hood and see if anything looks odd. With the car running and without. Post back and let us know.
Billy
Old 03-13-09, 08:58 PM
D
Strong Gas Smell
I have a 1996 Chevy Cavalier. 2.2 Liter standard transmission. Lately I have noticed a strong gas odor. A friend suggested that my fuel injectors might have a leak. Is this something real that happens. It doesn't overheat but has been using oil more then it used to. Any ideas?
Old 03-14-09, 06:31 AM
pugsl's Avatar
Received 77 Upvotes on 70 Posts
You have a gas leak someplace, Need to check ASAP. Real fire danger.
