Toyota 94 Rear Window Driver Side
Old 12-24-03, 07:15 AM
lou7
Smile Toyota 94 Rear Window Driver Side
How do I pop in a rear window on a 94 Toyota Corolla-driver side? My car was vandalized-window broken. I have a new window, can't pop it in, need step by step instructions, have inside door stuff off. Please assist. Thanks
Old 12-24-03, 10:22 AM
You need to remove the door panel, remove the window glass (two bolts).
You then need to remove the rear window channel, one screw under the weatherstrip on top. There may be 1 or 2 10mm head bolts along the middle to bottom. Then you can remove the 1/4 glass w/weatherstrip attached.
