12-26-03, 08:02 AM
babeface_28
brakes on 91 t-bird
hello all have a problem with the abs brakes on a sc t bird. the brakes was getting hard and not wanting to stop so after going to the dealer and they could not fix it i replaced the whole abs unit. now i have a brake light and anti-lock brake light coming on every time i hit the brake. i have bleed in 3 times and not getting any air any possible answers from anyone.
12-26-03, 01:52 PM
Ok, the dealer couldn't fix it and you did???????
You replaced the WHOLE ABS unit??????
What did you replace????
How do you know that was the problem?
It sounds like you still have air in the system but I don't know what your original problem was. Were you getting a brake or ABS light in the first place?
Sounds like you made more problems than you already had.
12-28-03, 03:09 PM
babeface_28
brakes on 91 t birds
my original problem was that the brakes would get hard when the car gets heated up but it is not running hot. i replaced the whole abs unit under the hood. it was a used part because buying it new they wanted 1300. its not getting hard any more but still its not right.
