swirl marks
Old 12-27-03, 03:21 PM
cproctor
swirl marks
PLEASE HELP, I HAVE A BLACK 96 Z71 THAT HAS SWIRLS ALL OVER IT. ANY TIPS ON HOW TO GET THESE TERIBLE LOOKING MARKS OFF MY TRUCK?
Old 12-27-03, 04:32 PM
billys68ss's Avatar
What caused the swirl marks? You might try to wax it or if it is real bad try to use a rubbing compound to soften the swirls.
Hope this is helpful to ya,
Billy
Old 12-27-03, 04:54 PM
cproctor
I THINK THEY CAME FROM WAXING WITH A BUFFER (THAT WANT HAPPEN AGAIN)
Old 12-27-03, 05:32 PM
darrell McCoy
I have had decent results with clay magic. But you must use plenty of the lube. on a black finish.
Old 12-27-03, 06:01 PM
Going back some years there was a product called Liquid Ebony made to remove swirl marks esp on black. Worked very well but was used with a buffer.
Today companies like 3M or Meguires have products for this pupose. They make products to be used with each other from start to finish, they call it a "system".Check any body paint supply or a well stocked auto store.
Black is the hardest color to buff properly, but when done right there is no better looking finish. Even some professional detailers will want to avoid black for that reason.
Old 12-27-03, 06:37 PM
jimmymc
This is the way I do it...of course, this is usually on fresh paint...fully cured paint just takes longer.
Use an electric variable speed buffer, a Mequair's white FOAM pad, 3m machine swirl mark remover for dark colors.
The pad should be damp and the car clean.
Take one panel at a time, put about 3 or 4 small drops of swirl mark remover on the panel. Run the buffer about 500 RPM over the panel...continue until all of swirl mark remover is gone.
If it starts to get dry I usually mist it with water and continue.
Apply your favorite hand glaze...with a very soft cloth or towel.
Goodluck jimmymc
Old 12-27-03, 06:48 PM
billys68ss's Avatar
If it got done from waxing then someone didnt keep the buffer clean. Small particles of dry wax will scratch just like sandpaper.
Billy
