serpentine belt layout
Can anyone send me a diagram of the belt layout for a 1997 Caravan with a 3.3 engine with air.
Thank you
Thank you
the picture is 135KB, i can't post it here, even if i knew how(to post it)
start on the alternator, down to the p/s pump, up to the auto tensioner(backside of belt), and down to the crankshaft.
going the other way from the alternator, go under the motor mount, to the little idler pulley, to the a/c compressor, backwards on the water pump, and back to the crank.
the easy way i do it, is to get everything on, except the little idler near the a/c, push the tensioner all the way down with a 15MM wrench, and at the same time pull the backside of the belt over that idler. it's always easier to finish the belt on it's 'back' side than pulling it over the grooved side.
if you want the picture, PM me with your email address
