Replacing Front Speakers in a 1995 Lumina Van
Old 01-04-04, 09:42 AM
H
hjustice
Does anyone know what is involved in changing the front speakers on a 95 Lumina minivan? Do you have to disassemble much of the dash or can you access the speakers w/o removing the dash?
Old 01-04-04, 09:50 AM
D
The speaker covers should pop off or remove by a couple of screws then the speaker should be able to be removed after removing the retaining screws.
Old 01-04-04, 10:28 AM
H
hjustice
Lumina Speakers
I tried popping off the grill and that doesn't work. Then I pulled up the rubber dash. Big mistake. Apparently it was glued in and now won't go back. Wife is mad since it's her van. What do you use to get the dash to go back. Any special kind of glue?
Still can't figure out how to get the speaker out.
