headlight sensor
Old 01-04-04, 09:50 AM
joanmarie
headlight sensor
i have a 2000 grand am....the headlights usually come on at startup...now the engine check light comes on and the headlights come on only at dark. plus, my interior overhead light won't come on unless i switch the on/off button a few times..it'll light up then go off. what do i do? thanks
Old 01-04-04, 09:59 AM
D
I would need some codes to help you,Autozone can't provide them.You don't by chance have your parking brake partially applied do you?As far as I know only a tech 2 can read body codes on GM vehicles so if it is not the parking brake you will need to go to a dealer to at least have the codes read.
