89 montero starter problem
Old 01-07-04, 05:02 PM
D
dogdocdavid
when I turn the key to start the truck, there is just a click and nothing else. This has been going on for some time....I would turn the key three or four times before the engine would turn over and start.....the battery was checked and was fine???? Is it in the ignition....the connection from the key to the starteror possibly the starter??????thanks
Old 01-07-04, 05:15 PM
the_tow_guy's Avatar
Received 48 Votes on 38 Posts
Likely the starter if you have checked all connections for corrosion and tightness. You can often check it by rapping on the starter itself with a hammer when it won't start. If it starts after rapping on it, bad starter.
Old 01-07-04, 05:59 PM
D
dogdocdavid
starter
thanks i will try to find the clicking noise....i assume it will be the starter..and I will knock the pooo out out it....kidding....i am also in Sarasota...born and raised....thanks
