anifreeze mixture
Old 01-08-04, 09:15 AM
iggyman73
anifreeze mixture
antifreeze mixture not right,ice chunks in radiator and maybe in motor,can i just start the car,heat up radiator,drain and add correct mixture or should i wait for a warm day before starting car
Old 01-08-04, 02:54 PM
I would probably recommend waiting until it thaws out.I f you have a timing belt and the coolant is frozen at the water pump it's not going to be a good thing.Best plan would be get it in a heated garage for about 24 hours and go from there.
Old 01-08-04, 04:46 PM
Desi501's Avatar
Don't leave it out in the cold while your deciding or you may have more problems thab you already have.
