97 Hyundi
Old 01-10-04, 09:33 AM
wally1
97 Hyundi
can anybody tell me how to take the drivers side door apart
without busting any of the clips. I need to fix or most likely
have to replace the outside door handle.
Old 01-10-04, 10:14 AM
the_tow_guy's Avatar
Received 51 Votes on 41 Posts
Best way is with the special tool that's made for the job. Check with your local discount parts store, should be able to get one for $10 or so. Looks like a pair of pliers but has flat nose that slips under panel to pop the panel loose.
Old 01-10-04, 01:19 PM
billys68ss's Avatar
And then you are still likely to bust some of the clips. Be prepared to buy a couple. They cant be too expensive. Some folks are proud of em, but im sure Hyundai isnt too bad.
Billy
Old 01-11-04, 11:08 AM
wally1
Question still have problem ?
having a problem with the inside door handle and window
crank. I can't seem to find the clip for the window crank,
and the inside door handle seems to be held in as one peice
even though i removed the screw
Old 01-11-04, 11:50 AM
billys68ss's Avatar
You are obviously missing a screw or clip. Look under anything that looks like it snaps out.
Billy
