Changing a thermostat in a Cavalier
Old 01-12-04, 07:49 AM
srhandy58
I am changing a thermostat in a 1997 Cavalier. The thermostat is located in one of two positions - either right next to the water pump, or about 6 inches away from the pump, where a radiator hose connects to a metal part that in turn connects to the pump. Does anyone know which is the location of the thermostat? Thanks.
Old 01-12-04, 09:44 AM
comtnman's Avatar
You should be able to follow the upper radiator hose back toward the engine to find the thermostat.
Old 01-12-04, 09:52 AM
Desi501's Avatar
We can't answer your questions if you don't tell us what your working on....like engine size
Old 01-12-04, 10:48 AM
srhandy58
The car is a 1997 Cavalier coupe, with a 2.2L engine. Also, at the point where the radiator hose meets the engine block, there is a stamp on the housing that advises the thermostat is located at the water pump. So, it is not at the classic location where most thermostats are located. But there are two possibilities near the water pump - either right next to pump itself or a little removed from the pump where the other radiator hose connects. ?? Thanks.
Old 01-12-04, 11:44 AM
billys68ss's Avatar
Looks to me like you just answered your own question. It should be right by the water pump.
Billy
Old 01-12-04, 12:28 PM
darrell McCoy
Dont just use any gasket handy, I would use an O.E.M. gasket on that.
Old 01-12-04, 12:40 PM
On your car the thermostat is in the outlet that the lower hose connects to at the engine.Drain your coolant first to avoid a mess.
Trackbacks are On
Pingbacks are On
Refbacks are On
