Electronic Seats
joanmarie's Avatar
01-13-04, 02:06 PM   #1
joanmarie
Electronic Seats
I have a 2000 pontiac Grand-Am with electronic seats to raise or lower your seating position after my son was driving with the seat down it will not raise up. I can hear the motor running when i trying raising by the switch. What are the possible problems or fixes?
darrell McCoy's Avatar
01-13-04, 03:06 PM   #2
darrell McCoy
Those are pretty delicate motors and gears. I would say a plastic gear has gone bad on you. If so, likely it is a dealer item only. Normally the seat has to come out for service.
joanmarie's Avatar
01-13-04, 10:34 PM   #3
joanmarie
power seat motor
Does this mean the motor will have to be replaced or repaired? Can any auto repair man do this, or does it have to be a pontiac dealer? What price range should I expect to be billed for? Thanks
01-14-04, 09:40 AM   #4
darrell McCoy
Time and labor consuming. Close to 3 hours. Motor assembly would be about 60 bucks if needed. Total would be close to 300 bucks. I suppose a good shop could do it for you, but at a dealer you should get a 12 month warranty on labor and parts, thats the way I would go as they would use O.E.M. parts.
