01-15-04, 01:34 PM
vshappy
I live in the Northeast and my window washer pump is frozen. Is there anything I can do before I bring my car to a mechanic? My car is a 2000 Nissan Altima GXE.
Thank you.
Thank you.
01-15-04, 02:18 PM
car_boy_16
Frozen!? Geez, I thought window washer fluid was suppose to handle like -30degs F before it freezes....Did you put water in there
Get a propane torch and heat it up, not too much, hold the torch about 4inches away and after a while it should thaw out and hopefully work again. Or you can take the pump out, bring it inside for a day or two then see if it works again....I dunno what to tell ya, I have never heard of a washer pump freezing!
Good Luck!
Good Luck!
