02 sensor
i have a 87 olds cutliss supreme v8 motor ,my problem is the 02 senser don;t last but about 2 or 3 months then i have to replace it. my question is can you bypass it or what could be causing this .the car runs good but smells real bad when the sensor goes bad . thanks in advance
You definately need some qualified diagnosis. O/2 sensors don't just "go bad". Either they get ruined by another problem or there wasn't anything wrong with them at all and they are just reporting correctly what they are seeing. Is your check engine light working and on? Have you scanned for other codes? Find out what's in there for codes and report back with them. Otherwise just get it into a reputable shop for correct diagnosis.
I agree something is causing the sensor to fail.toivo is right coolant or oil will do it.Another thing that will do it is leaded gas, in Pa you need your own tank and at least 5 acres to qualify as a farm to buy it.I will say this I have installed aftermarket O2 sensors that will no teven allow closed loop operation.So maybe you are getting low quality sensors I don't know.
