Heater woes.
Old 01-20-04, 05:37 AM
cshaner's Avatar
Heater woes.
*Friends car*
2000 Mitsubishi Eclipse RS
4 cylinder
5 speed
Heater only puts out warm air when gas pedal is pushed. Blows cold when parked or idling at lights. Car is kept in heated garage overnight, allowed to run approx 10 minutes before driving.
No dampness in floorboard or musty/unusual smell. No unusual sounds. Flush and fill performed within the past three months.
Thanks in advance for any info.
Old 01-20-04, 06:46 AM
darrell McCoy
again, feel the hoses, may just be thermostat time. What does the temp guage read. C-N-H.??
Old 01-20-04, 07:04 AM
cshaner's Avatar
Re: Re: Heater woes
Guage reads normal. Starts at cold and works its way up to normal as usual.
Old 01-20-04, 08:40 AM
darrell McCoy
Then, you may either have a plugged heater core or your heat control or air deflector doors are in operative. Do both your heater hoses get hot, where they enter firewall?
Old 01-21-04, 06:56 AM
cshaner's Avatar
Re: Heater woes
Friend took the car to corner garage. Mechanic says it was very low on antifreeze and is currently "tuning it up".........
Old 01-21-04, 10:45 AM
darrell McCoy
Yep low coolant will do that also, I assumed the owner would periodically check that as routine maint.
Trackbacks are On
Pingbacks are On
Refbacks are On
