96 Tahoe
Old 01-22-04, 11:50 PM
ShaSha
Question 96 Tahoe
Last week I noticed the interior lights weren't shutting off as they usually would. Now I have removed the #3 fuse, which is OK until I need my lights at nighttime. What might be causing these lights to stay on?
Old 01-23-04, 02:17 AM
Y
This may be out there and I'm sure you know this but just in case, In your car up by the light there should be a switch which will give you the opion to keep the light on all the time , or it will turn the light on when ever the door is open & then turn off when the door is closed, and some cars have the lights that turn on as soon as a key is put in the door and it stays on for a minite or so after the door is closed.
Are you sure you don't have the light set-up so it's on all the time.
Old 01-23-04, 04:45 PM
D
Door latch switch could be bad also or on the rear gate.Do you have a dome overide button on the dash?
