tune up on a 99 Ford Mustang
Old 01-23-04, 10:50 PM
remnant1
I usually take my car to the shop to get it tuned up, but I want to start doing it myself cause they charge me $120 on a tune up. This is my first car and dont know anything about them so if you can, please explain in detail on how to tune up my 99 ford mustang.+ If you have any good tips on how to keep my car running good I'd really appriciate it.
Old 01-24-04, 05:18 AM
hogfan's Avatar
What size engine,how many miles are on the car? Maintenance is the number one thing you can do to help with the life of our car! Has it had a 30k service this is done at every 30 thousand miles, Usually it's a trans service,coolant flush,brake inspect,tires rotor,belt and hoses inspect,battery inspect and test and so on. A tune up in your owners manual is about 100 thousand mile service. I hope this helps.
Old 01-24-04, 10:44 AM
remnant1
Its a V6 and has 100,965.0 . I got it from my cousin so I dont have the owners manual.
Old 01-24-04, 04:43 PM
Y
For your car, I'll give you a list of things:
Change engine oil and replace Oil filter,
Inspect brake pads/ Shoes/ Rotors, brake lines and hoses,
Inspect Radiator hoses
Replace coolant ( make sure you get the right color),
Inspect exhaust system and heat shields
Inspect steering linkage, and suspension,
Replace engine air filter (if you have the cash get a K&N Filter),
Replace fuel filter
Replace cabit air filter if you have one ( I don't think you do),
Replace all the drive belts ( Most likely they were never replaced),
Change Tranny fluid
Rotate tires
Replace Plugs
