fuel injectors
Old 01-29-04, 03:26 PM
fuel injectors
My son has a 1989 Acura Integra LS. There is some wetness around two of the fuel injectors and ther is a slight smell of gas.
I saw several autoparts stores on the internet selling injector O-rings (and also injectors) for that car.
I assume that replacing the O-rings is not a terribly difficult job to do yourself. Am I correct in this?
Old 01-29-04, 04:37 PM
Desi501's Avatar
Some cars are harder than others. The main thing is you have to have enough access to remove the fuel rail. I little inspection should give you an idea how much work that is. Try to get it diagnosed accuratly before dissassembly because it could be either the injector itself or the O-ring, or even the rail that is leaking.
