brakes
Old 02-01-04, 06:55 AM
kennyh
Red face brakes
I have a 2002 F150 king cab 4.6 XLT 53000 mi. when I try to stop I would hear a roaring,grinding noise so I checked the front pads. They needed replacing so I put new pads on, Raybestos QS couldn't turn the rotors because they had runout. After 2000 mi. the roaring noise returned so i returned the Raybestos QS pads. The next thing I did I bought NAPA TS pads,front rotors,bearings and seals I also replaced the rear pads with NAPA brand and turned the rear rotors,oh by the way I bought a bearing packer too. My problem is after 2000mi. more the roaring noise is back, not as bad but it's getting there. I've been replacing brakes on my cars for 20yrs and I've never had this problem. The truck is still under warranty. Could someone please help!!!!!!!!
Thanks,
Kennyh
Old 02-01-04, 02:10 PM
Desi501's Avatar
Check your front tires for cupping. This will cause a roar that will get louder when braking. I don't have any other ideas, assuming your noise is coming from the front.
Old 02-01-04, 03:02 PM
billys68ss's Avatar
You say you didnt turn the rotors due to runout. Did you replace them? Or are the same rotors still on there?
Billy
Old 02-01-04, 04:43 PM
Desi501's Avatar
Re: brakes
Yes, he said he replaced them. Not much left to blame????
Old 02-01-04, 05:18 PM
billys68ss's Avatar
Sorry.... I dont see where he said that he "changed" the rotors.
Billy
Old 02-01-04, 06:18 PM
Desi501's Avatar
He didn't do anything with them the first time but the second time he replaced the pads, front rotors, bearings and seals and he turned the rear rotors.
Old 02-02-04, 04:42 AM
billys68ss's Avatar
I see that now.... OOPS!!! I had to read the darn thing 5 times to see that and just daw it this morning. HMMMM..... Must have been off kilter yesterday.
Describe the noise please.... Tire noise will not be grinding... roaring and thumping, but not grinding.
Billy
Old 02-02-04, 11:28 AM
kennyh
brakes
A roaring noise when i'm stopping
Old 02-02-04, 12:57 PM
How are you seating the front bearings???
Desi501's Avatar
Re: brakes
That could be tires.
Old 02-02-04, 02:17 PM
Rotate your tires front to rear and see if it changes.If it does it's your tires.
Old 02-02-04, 10:09 PM
mike from nj
possibly, could be tires.
but how would the roaring noise disappear only when replacing the brakes, and return twice at 2000 mile intervals, and then needing brakes again?
i would be looking for a dragging caliper, seized caliper mount, misadjusted master cylinder, collapsed hose, or even contamination of the braking system.
were the pads metal to metal each time you inspected them??
why are you fixing it if it's under warranty?
Trackbacks are On
Pingbacks are On
Refbacks are On
