flashers wont work
Old 02-01-04, 10:46 AM
chuck_john2000
flashers wont work
I have a 1996 dodge intreaped car, 3.3 engine, my flashers or bleankers dont work, I dont have a blown fuse, but I cant find where the flasher is at and nobody knows at the auto parts place, Please help if you can.
Old 02-01-04, 01:37 PM
Desi501's Avatar
If I remember correctly, it's a flasher "module" up under the dash on the drivers side.
Old 02-01-04, 08:15 PM
mike from nj
there should be a fuse in the dash and one under the hood feeding this circuit.
the combo flasher under the dash feeds both the turn signals and the hazards. it should look like a regular relay(black)and be behind the fuse block. you will need to remove the lower portion of the dash (the knee blocker) to see it.
a dealer would know what it looks like.
Old 02-02-04, 09:05 PM
I just got a 95 Intrepid and had the same problem.
Check the positive battery cable, there might be a smaller wire connected to it. If there is, check and make sure its making contact.
That was my problem. I cleaned it and reconnected it and everything works fine.
