Wipers Pontiac
Old 02-02-04, 10:13 AM
chevyred55
Question Wipers Pontiac
Can someone tell me how to remove wiper arms from studs on a 2001 Pontiac Firebird? I know you raise the lower portion of arm and remove hold down nut, but does it take some type puller to actually get the arm off? Need to reset arms so wipers don't
hit the side post on windshield.
Old 02-02-04, 10:16 AM
tstokka
if you look near the hinge there is a hole or a clip there. Pull up on the blade and stick something in the hole to keep it up, if its a clip slide the clip till the blade isn't resting on the windshield. These are the only two systems i've seen
your fighting the pressure of the spring that keeps the blade against the glass.
Trackbacks are On
Pingbacks are On
Refbacks are On
