clutch problem
clutch problem
I have a 97 eagle talon. Recently my clutch has felt really soft, almost like the tension is going. While I'm driving it's getting harder and harder to shift due to the clutch. I let the car sit in the garage for a couple of days and now the clutch doesn't have any tension to it at all. I get pop the clutch even to start the car. Before I bring it to the mechanic, can anyone please tell me what they think the problem is so I don't get screwed over.
Thanks alot to any suggestions
Scott
Scott
Sounds like you have a hydraulic clutch that has a leak. Chech the clutch Master reservior under the hood.
It either the Clutch master or the slave. Look under the dash where the rod connects to the clutch pedal and see if it's wet. You may have to pull back the carpet to see. If so the Clutch master is NG.
