Fast Flasher on Left turn 2001 F150 4X4
Old 02-07-04, 03:56 PM
aaron_eckhoff
Question Fast Flasher on Left turn 2001 F150 4X4
When I indicate a left turn I get a rapid blinker, the left rear
light flashes fast the left front nothing. I replaced the bulb (tried two known good bulbs) Switched out the socket with the working one, checked the fuses, tried a BFH!!! still no go..
Truck is out of warrenty...Dealer says it can't be the flasher
unit or nothing would work.....PLEASE HELP!!!
Old 02-07-04, 04:17 PM
Desi501's Avatar
It's not the flasher. The problem is the front one not working. Your going to have to find out why. It may be a ground problem. Usually the problem is right in the pigtail. There should be a verticle strap inside the socket that contacts the side of the bulb, see if that is intact. You may have to use a testlight to test for powers and ground to find the problem. If the problem turns out to be the pigtail, it's easy to snip off the old one and splice a new one in.
Old 02-12-04, 12:28 PM
PNUT883
you said you tried two good bulbs. one in front and one in back or in the same socket. sounds like a stupid question but just curious
Old 03-01-04, 06:40 AM
aaron_eckhoff
no both in front because the rear works.
Old 03-01-04, 02:18 PM
hazard flasher
Try your hazard flashers and see with bulb does not work.
Old 03-01-04, 03:32 PM
aaron_eckhoff
Re: hazard flasher
ok tried Hazards and all but the front left work which is the one I have been working on.
Old 03-01-04, 04:10 PM
Ok
Ok we know it is not the flasher.My next thing I would check is all connections to that light.Can you swap out the assembly from rigt to left just for testing?You will need a DVOM for furter testing after that.But first I would clean all connections real good with a small file or pick.
