front end vibs
Received 0 Votes
front end vibs
My 86 Corolla FWD is experiencing some vibration at freeway speeds. Rebalanced all 4 tires but did not go away. When I turn the wheel slightly to the left, as in a sweeping turn, it gets worst. It feels and sounds like going over rough pavement. Turning the wheel to the right does not do this. Any ideals?
them guys has great suggestions but i wouls also try rotating the tires LF TO RR---------RF TO LR ,THE 2 REARS GOES STRAIGHT UP TO THE FRONT...dont cross the front maybe this is something you can do at home with no out pocket money....if this dont work then check the wheels good luck
Received 0 Votes
Tires were rebalanced and rotated but did not help.
Jacked the front end up and checked the wheels for play. Right front wheel has some play when pushed at 9 o'clock & 3 o'clock, but none at 6 & 12.. No play was found with the left wheel in any direction.
Bad rack and pinion?
Received 0 Votes
It feels like driving on the frwy where the concrete road bed meets with the asphaut shoulder and the tire is right on top of the crack. The vibration interval is much closer together than going over the wake-up strips, so I guess it would be closer to like going over the steel grates.
New Member
Received 0 Votes
sounds like wheel bearing. I'd try jacking front end up, block rear wheels, put in neutral, then spin each front wheel. Listen carefuly while spinning if it's a bearing you'll hear it growling. That's been my experience.
Good Luck!
Good Luck!
Received 0 Votes
Will check it out again tomorrow with the spin test. If it is a bad wheel bearing, wouldn't you get the same amount of play, regardless which way you wiggle the tire, not just left and right?
i've seen very worn tie-rod ends make a clunking/vibrating type noise and have a steering wheel vibration too. these are VERY worn ones.
i never tried the slow left/right turning to load/unload it, so i can't say how it reacted to that. if you turn the steering wheel left/right quickly while going slow, it would clunk each time.
get a flashlight, look under the car while someone rocks the wheel at the 3&9 positions and you should be able to see what's worn.
you might have two problems, as a wheel bearing can be very noisy even with NO play in it.
let us know
let us know
I have never heard one bad by spining the wheel by hand. Have heard them by running with wheels off the ground at 20-50 mph.
Most of the time there will be no play in a bad front bearing on that type car.
Received 0 Votes
Rechecked the play of the right front wheel. Wheel spins ok. There is play when rocking at 9&3 with the arm that connects to the rack and pinion. If I remove the boot that covers the arm, will I be able to adjust or replace anything? Or do I need to replace the whole thing? There is no play with the arm to the left wheel.
Would it be safe to do the 25-50mph test by blocking the rear wheels and jacking up the right front wheel at the lower A-arm? I take it this is to detect a noisy bearing?
As long as it's done in safe manner. Jack it up, us a jack stand, have some one else run the car up to speed, stand clear of the front. Make sure ther is nothing in front you can run into. Stay clear of the spinning tire. And
USE COMMON SENSE AND GOOD JUDGEMENT
and of course PERFORM AT YOUR OWN RISK
Received 0 Votes
I replaced the inner tie rod this weekend and took it in for an alignment. The alignment guy said everything else looked ok. No more vibrations. Thanks to everyone who replied!
