98 Ford Escort ZX2 fan relay
Old 02-10-04, 08:58 AM
kkelly95
I have a '98 ford zx2 and the cooling fan does not shut off. it runs constantly and i had to remove the fuse to stop it. i thought that the fan relay went bad, but i've checked at part stores and there is no fan relay listed. could there be another problem or am i missing something. any help would be appreciated.
Old 02-10-04, 10:26 AM
Desi501's Avatar
The relay is likely built into a combo unit/module along with the A/C clutch relay. It is usually mounted around the radiator behind the L/F headlamp. Sometimes they have been know to be behind the glove box also.
Old 02-10-04, 01:25 PM
kkelly95
Smile
Thanks for your help Desi501. I appreciate the quick response. i'll let you know how i make out.
