94 3000gt just died
Old 02-10-04, 09:48 PM
Negoshe8n
94 3000gt just died
My fiancee has a 94 non turbo 3000gt automatic. It has the 4 cam 3.0 v6. Most of the day it sounded like a belt going bad. Slight squeel at idle. Just before the car died it had a very slight rattling noise then in a minute or few the car just died. The front cam cover smells like a burnt...The timing belt was changed 20k ago. It just cut off, no noise or anything. The motor cranks without any unusual noise. Would a cam sensor cause this? If so is it under the cam cover? I do see a wire going under the timing belt cover. I'm not to familiar with the sensors on this car. What about a broken or loose timing tensoner?
Old 02-10-04, 10:53 PM
mike from nj
i think the cam sensor is on the rear of the cam, near the trans side. that wire you see goes to the detonation sensor in the valley of the engine.
take off the upper timing covers and look down inside with a flashlight to see if anything looks 'not straight' with the other pulleys. could be a tensioner, idler, or even the water pump. is any coolant dripping from the bottom? is there any excessive slack in the belt? try to line up the marks on the gears and see if anything is out of alignment.
a timing belt is not a fun job on these engines.
Trackbacks are On
Pingbacks are On
Refbacks are On
