caddy won't run
Old 02-11-04, 09:31 AM
P
Angry caddy won't run
I have a 1994 Caddy Deville,V8, 4.9 liter. The car will start and run, but the lights will soon dim, panel will dim and the car will stop running .... I heard that this sounds like an alternater problem ..any other suggestions.. and how hard is an alternator to replace by an amatuer?
Old 02-11-04, 10:30 AM
Desi501's Avatar
You've already been told it's an alternator, that sounds right. Have it tested and replace it with a reman unit if it tests bad. Your also going to need a battery if you keep driving it that way.
Old 02-11-04, 10:47 AM
P
thanks...
I'll get it tested today ..BTW how hard is it to remove and install..
doesn't look to complicated
Old 02-12-04, 09:43 AM
P
Caddy won't run
OK .. I tookk the alternator to auto zone and it checked out ok .. and I also got a new battery ... so if it's not the alternator or the battery ..anyboady has a clue as to what else can it be
