torque requirement
jem8745's Avatar
02-13-04, 04:58 AM   #1
torque requirement
I am replacing a front, wheel bearing hub assembly on a 1991 Buick Park Avenue. I need the torque specifications for the axle nut.
Thanks for the help. Jim
Desi501's Avatar
02-13-04, 04:50 PM   #2
As tight as you can get it will 1/2 inch drive ratchet, bar or impact gun.
mike from nj's Avatar
02-14-04, 11:13 PM   #3
mike from nj
VFT! (very tight)
i'll let you figure out the f-part. when i used to torque stuff, i sorta remember the number 180 ft/lbs, maybe?
you should be able to find the number in any library if nobody gives you a spec here.
