clutch trouble
Old 02-13-04, 12:05 PM
A
clutch trouble
My car: Honda 1995 Accord LX 2.2
My car was sitting outside in the cold after spending time in the garage. I got in the car and pushed down the clutch and there seemed to be a lot of play - i could push it down about 2-3 inches before it was somewhat firm. When i first start to drive i can barely shift it. it doesn't grind, but its near impossible to get it into gear. After i get going the shifting gets easier, however the pedal still has the same amount of play and softness. any ideas?
Thanks.
Charlie
Old 02-13-04, 02:11 PM
raharold's Avatar
I assume it didn't do this before it sat for a while? Did you check the clutch master cylinder fluid level? If it is low you probably have a leak some where.
Old 02-13-04, 02:13 PM
A
actually it only sat overnight.
i didn't check the fluid yet.. wanted to see what anyone thought might be the trouble.
Old 02-13-04, 04:46 PM
Desi501's Avatar
Sounds like a fluid leak for sure. Change bothe the clutch Master and the slave cylinder to avoid future problems.
