Transmission Prob After Changing Wheel Barrings
Old 02-15-04, 10:16 AM
secret4g
1992 saturn sl
i changed my front wheel barrings and now my car will not go in reverse all other geers are fine but when i put it in reverse it just makes a grinding noise. could this be something i done wrong when putting cv joints bak on? this is an automatic transmission
Old 02-15-04, 12:52 PM
secret4g
I HAVE A 1992 SATURN SL W/ AUTO TRANS.RECENTLY I CHANGED FRONT WHEEL BARRINGS AND NOW MY CAR WILL NOT GO INTO REVERSE, IT JUST SPINS AND HAS A GRINDING NOISE. ALL OTHER GEARS ARE GOOD. I HAVE CHECKED EVERYTHING I CAN THINK OF AND ALSO SUGGESTIONS FROM OTHERS. IF ANYONE HAS ANY IDEAS I WOULD REALY APPRECIATE THEM. THANK YOU IN ADVANCE
Old 02-15-04, 02:51 PM
D
Make sure both halfshafts are completely in the trans if one isn't remove it and check the splines on the plunge joint for damage.
Old 02-15-04, 04:10 PM
D
Please don't post twice sometimes we need a little time to answer we are not sitting here waiting we have other things to do as do you.I answered your question in your second post and please don't caplock for attention.I decided to merge your threads for continuity.
