getting feet wet
Old 02-16-04, 07:38 PM
A
acdc
getting feet wet
I own a 1997 pontiac transport and noticed the front carpets are wet does someone have an idea were this source of water is coming from . I checked under and everything seems normal.
Old 02-17-04, 03:36 AM
Desi501's Avatar
First, check your coolant level. It can be any one of 3 things
Heater core leaking coolant into car
A/C condensation drain plugged and leaking into car (can happen when using defrost mode)
An overhead rainwater leak finding it's way to floorboard.
Old 02-17-04, 04:11 AM
carguyinva's Avatar
or just plain...
...water from all the snow and ice you track into your vehicle...it's hard to say, you give us very little extra information to apply here.
Old 02-17-04, 09:26 PM
F
fordman30
theres a L tube in the firewall where the the water from your A/C leaks out is it stop up.pull the rubber tube off and get a wire clothes hanger and stuff it in there to clean it out... HOPE THIS HELPS.. LET US KNOW
