caddy still won't run
Old 02-18-04, 05:20 PM
Unhappy caddy still won't run
Ok ..it's a 1994 Caddy Seville .. the battery is good (brand new) the alternator is good ... checked it out at Autozone and it's ok.. The issue is the car will start and run ..but soon the lights will dim and sometime you get a waring about now electrical charge ..then the car stops running .. what could be causing this problem ... looking for help..
Old 02-18-04, 05:56 PM
Desi501's Avatar
In the past we advised you to have the vehicle tested for battery, alternator and current draw. Taking it to Auto Zone won't tell much. It needs to be load tested in the vehicle and do a diode check while in the vehicle.
