1983 olds 5l. 305 ci. hei? carburator
maitai11's Avatar
02-18-04, 06:12 PM   #1
i was driving along and it just konked out like its not getting spark maybe. hard starting and runs weak if i dont hit the gas. i'm gonna replace the cap and rotor but is there a test for the coil? resistance maybe?
JungleJim's Avatar
CANADA
02-18-04, 07:14 PM   #2
had an '83 Cutlass, had the same kind off trouble. It was the ignition module. When you take the top off the distributer, you'll see it. Just a thought.
carguyinva's Avatar
VA
02-19-04, 04:56 AM   #3
there's many possibilities...
...but to answer your question about ignition coils...yes, there is a resistance test. for an HEI coil the spec for the primary winding is .5 - 1.0 ohm and for the secondary winding it's 6,000 - 30,000 ohms.
you could put a spark tester on it, they generally put enough load on the coil to rule out a weak one and dynamic testing is better than using an ohm meter.
when was the last time it had a fuel filter?
ign modules are testable at most parts stores.
perhaps you could give a more detailed description of what it does and we could offer more direct advice...
Desi501's Avatar
02-19-04, 05:07 AM   #4
I agree with carguyinva that there are many possibilities and ignition wouldn't be my first suspect. Generally when a module quits, it yes or no with spark. When a coil goes bad, it's usually load that cripples it. I would start out looking hard at fuel supply AND QUALITY. I've seen water in the fuel act like that too.
