turn signal wiring on 95 gmc
Old 02-19-04, 04:28 PM
F
frankie2
I am replacing the turn signal switch on my Jimmy and am having a heck of a time pulling apart the electrical wiring "harness". I'm worried about pulling out the wires or breaking the plastic casing. Anyone know an effective way to do this? Thanks
Old 02-19-04, 05:37 PM
F
fordman30
make sure it doesnt have any small clips where the wires attaches to the main harness beside the bottom part of the steering column.....this would be my only suggestion.but i have one but cant tell you about it on here
Old 02-19-04, 05:39 PM
Desi501's Avatar
I believe it passes through a plastic enclosure as it goes down the column. You have to release it from the bottom to slide it up the column.
Old 02-20-04, 09:49 PM
U
u2slow
That signal switch has a good chunk of wire (12" or so) that stays with it. The connector unplugs further down the column. I know it *looks* like it unplugs near the switch itself, but it doesn't.
